HOW CAN I GET STILL PHOTOS FROM A MOVIE RECORDED ON DVD.
Results 1 to 12 of 12
YOU CAN PUT IT IN A DVD-ROM DRIVE AND PLAY IT WITH SOFTWARE LIKE POWER DVD, FIND THE IMAGE YOU WANT AND HIT THE CAPTURE ICON (THE ONE THAT LOOKS LIKE A LITTLE CAMERA).
AND BY THE WAY, I THINK YOUR KEYBOARD IS BROKEN - YOUR 'CAPS-LOCK' KEY SEEMS TO BE JAMMED!- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Actually my caps lock key is not jammed i deliberately put my message and caps BUT THANKS FOR YOUR HELP!!!
When you use all caps, it is considered hostile and shouting. It is also considered bad net etiquette. Less people will want to help you.
damn, and I tried to give you the benefit of the doubt....Originally Posted by frostyrky
- housepig
Housepig Records
out now:
Don't do that.Originally Posted by frostyrky
Also try to put a topic that relates to your problem....
Stops asses like us having to post silly comments about you lack of common curtsey...Not bothered by small problems...
Spend a night alone with a mosquito -
HP do a program called HP Memories Disc Creator, came bundled with my new printer. Seems a good program think it only does vcd though.
"photo slideshow on dvd" in google brings up
http://uk.search.yahoo.com/search/ukie?p=photo+slideshow+on+dvd&ei=UTF-8&fr=fp-tab-web-t&x=wrt&y=i -
You need to learn to use punctuation too.Originally Posted by frostyrky
You have blended two sentences. -
LOL!Stops asses like us having to post silly comments about you lack of common curtsey...
keyboard help urgent
By dnmnbg in forum ComputerReplies: 2Last Post: 3rd Apr 2012, 22:45 -
AVStoDvd Help, urgent
By DaneClark in forum Authoring (DVD)Replies: 1Last Post: 21st Oct 2010, 21:22 -
Software help, URGENT
By ianbeddow in forum EditingReplies: 4Last Post: 6th Aug 2010, 05:23 -
messenger urgent help!
By alintatoc in forum ComputerReplies: 2Last Post: 1st Jun 2009, 10:39 -
Urgent computer help
By Seasonal in forum ComputerReplies: 24Last Post: 23rd Jul 2008, 03:49
