I keep getting an error relating to an mplvpx.dll that could not be loaded by the OS. I have looked everywhere for information relating to the mplvpx.dll but only find stuff about mplapx.dll.
I thought reinstalling WMP9 would work, it didn't. Then I upgraded to the beta WMP10 and that still hasn't corrected the issue. Anyone have any ideas?
Thanks for your help.
Results 1 to 15 of 15
Bleech
Hello,
I have two suggestions:
Check www.microsoft.com in the support section if you haven't already.
Also, try doing a net search (yahoo, msn, etc..) for mplvpx.dll and see what pops up. I can't imagine there's NOTHING out there. Believe me, somebody has had a problem similar to yours. Good luck.
I tryed Microsoft's KB. Nothing comes up for "mplvpx.dll."
I've tried Google as well. Nothing of useful help there.
See for yourself:
http://www.google.com/search?hl=en&ie=UTF-8&q=mplvpx.dll&btnG=Google+Search
Thanks for replying.Bleech -
Hello,
Sorry, just thought I'd mention it anyway. Sometimes we tend to forget easy solutions. I guess yours is a little more involved after all.
Believe me, I don't ask for help unless stumped and this problem has been bugging me for a while.Bleech -
Hello,
Sure. I just thought of something, how long has it been since you've run a virus check?? I remember awhile ago having some anonymous file error popping up. Turns out it was a virus. Could be a similar problem. Just another suggestion, obviously I'm not sure what it could be. Good luck.
just remove the instance from your win.ini file or your startup, then it wont look for it. if everythings working fine, but you get that error, just remove the instances and everything will work fine.
I have Norton Antivirus Corp Edt. latest and greatest defs. They update automatically without my knowledge. Last time I checked the date on them it was 21/7/2004.
I always have Spybot (w/TeaTimer in the background) and Adware running once a week.
I believe I have traced the problem back to a program I install and then uninstalled a while back. It was Ulead. However I don't see why the problem keeps coming back if the program is gone.Bleech -
It doesn't happen when Windows starts up. Only when I play certain videos with WMP.Originally Posted by hexxisoftBleech
Hello,
If that's the case you may want to try to recopy that file back to your computer. I'm sure you remember when you uninstall programs sometimes it asks "are you sure you want to delete this shared file?". I believe that may be part of your problem. You probably removed everything. That shouldn't be a problem but maybe it is now.ruscorp-It was Ulead. However I don't see why the problem keeps coming back if the program is gone
I suggest you try searching your ulead install disc for that file if you downloaded it try uleads tech support for suggestions. Hope this helps.
Kevin
p.s. Is your ulead directory still intact? IF you find the file try copying into each remaining folder, and windows xp main directory while your at it. It's still looking for that file for some reason (not a clean uninstall perhaps??)Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I'll try that out when I get home and get back to you on whether that worked or not.
When I uninstall things I have a tendency to do that.Bleech -
mplvpx - mplvpx.dll - DLL Information
DLL File: mplvpx or mplvpx.dll
DLL Name: Microsoft Media Player DLL
Description: Contains Functions used by Microsoft Media Player for Video playback
Part Of: Microsoft Media Player
System DLL: No
Common Errors: File Not Found, Missing File, Exception Errors
http://www.liutilities.com/products/wintaskspro/dlllibrary/mplvpx/ -
Yes, I did have it installed at one time.Originally Posted by Pop's
I've had problems ever since I uninstalled it.Bleech
DirectVobsub and WMP 12
By mrcoolekin in forum Software PlayingReplies: 4Last Post: 27th Apr 2012, 02:49 -
Wmp
By aaahza in forum Software PlayingReplies: 1Last Post: 23rd Feb 2011, 03:03 -
dvrms not seen in wmp 12
By Modify_inc in forum Newbie / General discussionsReplies: 0Last Post: 1st May 2010, 16:08 -
WMP StretchToFit
By jamesearljames in forum ProgrammingReplies: 0Last Post: 19th Oct 2009, 13:04 -
WMP
By marlo in forum AudioReplies: 0Last Post: 23rd Nov 2007, 15:50
