im planning to add a new hard drive, currently i have 250gig UDMA/100...i like to get the SATA i dont know if my motherboard will support it (i have no documentation that it will, never opened the case too, tried sony website no help) do i have to get a host controller for the SATA.. or just get UDMA/133 will it be suffecient? ,ill be using it for video storage when encoding. ill like ur input guys..ty
by the way wat brand is better, i heard seagate or western digital. ..ty again![]()
Never used SATA. See no need for the added cost.
I believe Seagate has a better reputation. -
SATA drives are pretty close to the same cost as ATA drives are now, the only difference being those awesome 10k Raptor SATA drives which are totally worth the cost. From what I've seen with regular SATA drives there isn't too much performance increase over ATA. One thing I don't like is the SATA connectors. Try to get cables that have right-angle heads on them for the HDD connector. The ones that stick straight in are surprisingly easy to break.
thanks for the replies,
if not much performance increase with SATA ill be better off with ATA then? coz SATA is a little bit expensive compared to regular ATA plus i think i have to buy PCI host adapter for SATA i dont think u can just plug this baby right to ur motherboard...im buying Seagate UDMA/133 then..thank you. -
Good knowledge on this post. I totally agree, nearly all my drives are SATA and I notice NO difference between them and my two IDE's.Originally Posted by rallynavvie
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Connecting SATA hard drive in IDE PC
By alegator in forum ComputerReplies: 17Last Post: 13th Apr 2010, 15:00 -
How to connect a 2.5" SATA hard drive ?
By SingSing in forum ComputerReplies: 2Last Post: 2nd Apr 2010, 22:19 -
Installing Vista on a Sata hard drive
By xtreemman in forum ComputerReplies: 11Last Post: 31st Dec 2008, 16:48 -
My first SATA hard drive looked lonely, so I got it another...
By Eldelli in forum ComputerReplies: 5Last Post: 25th Sep 2007, 22:21
