  1. i hae recently downloaded a file that is riff cdxa. does anyone knoe what this is and how can i play it on media player or even convert it to dvd?
    i was looking up from my bed at the stars when i wondered....Where the hells my ceiling?????
  2. Member Grimey's Avatar
    May 2004
    Canada Eh?
    Is there an bin and cue file? you probably need to mount the image, then install the riff/cdxa filter fromhere to play it.
  3. no when its downloaded it just looks a normal mpeg. i put it in gspotto find out what codec it was.
    how does this filter work can you play it on your normal media player after?
  4. If you have problems with riffcdxa encode the file with "handbrake" into x264/265 ans you have a compatible file
