  1. Hi guys,
    been a while since I posted,
    anyway I have a small clip (of my workplace) on DVD that I want to duplicate for some work buddies.
    Since it is only 13 minutes I didnt want to go to the expense of making DVDs for them ( i need to make about 10 copies), so I ripped it with IMTOO tool to a mpeg1 file & copied it to CD.
    Plays OK on my PC but wont play on my E30 DVD player. Is that correct since my DVD player says it will play VCDs (& isnt a VCD an mpeg file??) or am I wrong here.
    Some of these guys have DVD players as well as PC & macs.
    Is there a fromat (apart from DVD) that will play on :
    a. Their PCs & macs as well as
    b. There home DVD players.
    Or am I a bit optimistic here.............
    cheers
    just a mpeg file is not a vcd. you must author and burn it as a vcd, click on AUTHOR here to the left and click on VCD.
    and a VCD will play on computers and most dvd players.
    Mar 2003
    Uranus
    A VCD is an MPEG1 file surrounded by some formatting stuff.
    There are a number of VCD and SVCD authoring tools around.
    Try VCD easy. There are restrictions to the MPEG1 however.
    Your's may not be compliant. See WhatIs on the left
  4. Ok many thanks,
    I used VCD Easy to make a VCD & it plays OK in my DVD on a CD,
    thanks again
