I have an ntsc DVD image that doesn't have a file type or suffix. I'm not sure if it's an .img, .iso, or whatever. VLC plays back the movie content just fine, but it's not recognized by Toast as a burnable DVD image file. Instead, I get "Toast could not detect the format of [file]. Click Continue if you are sure it is a valid disc image."
Then, it offers a dialog with a sector selection menu. No matter what I select, it always describes the resulting file as a 4.3 GB CD-ROM XA.
Any ideas?
Closed Thread
Results 1 to 13 of 13
Apparently you are able to mount the disc image in order to play its contents. If that is the case, then mount the image file and drag the enclosed VIDEO_TS folder to the Toast Data tab (after you first select New Disc in Toast). Add an empty AUDIO_TS folder and click burn.
that should work just fine if
or you can attempt to add extensions
.img
.dmg
etc, until you get toast to find one. Thing is does it open dvd player when you mount the image? if not then its not a proper dvd image [assuming you have auto launch dvdplayer activated] and you will HAVE to do it the way above
I'm unable to mount the image, but VLC still plays it. Basically, it's just a file with no .dmg, .img, .iso, no nothing, but for someone reason it's still watchable with both VLC and Mplayer.
I've tried adding every file extension I can think of and Toast refuses to recognize the DVD image.
Here's what happens when I drop the DVD image file (with no extension) on Toast 6.0.5's Video pane:
"[file] is an unsupported format and cannot be imported."
how do you know its an image? and not some odd codex file that vlc just happens to play?
Where did you get this thing from?!?
hmmm ......
i see now.
well i dont think we can offer any more suggestions. My suspision is that its a strange image format since you have exhausted all possibilities
at risk of locking this topic i say we just drop this one.
ok.
guys, putting this one to a rest.
Its a downloaded dvd image.
How to Extract an ISO Image without burning to dvd?
By skorpinok in forum ComputerReplies: 8Last Post: 26th Sep 2018, 02:07 -
Problem burning subtitles and movie to DVD with Toast
By Akominatus in forum MacReplies: 40Last Post: 14th Apr 2013, 14:28 -
Burning a DVD ripped with MTR without the Toast application
By FilmLabAsst in forum Newbie / General discussionsReplies: 1Last Post: 20th Sep 2010, 11:58 -
burning a DVD in Toast
By lalilyman in forum Authoring (DVD)Replies: 3Last Post: 30th Mar 2010, 22:11 -
fixing bad sectors/Toast disk image
By danielmak in forum MacReplies: 6Last Post: 26th Jun 2008, 05:35
