I have a few videos encoded thru tmpgenc with some tinkering. What I want is to convert my mpeg2 videos to VOB bypassing the dvd standards.
Like bypassing the 25 fps for NTSC and so on...
Is it possable?
Hello,
Anything's possible with dvd. You just might not be able to play it on any regular dvd player. PC dvdplayers will play just about anything. I'd suggest you use a rewritable disc first before you make any coasters
Kevin
P.S. It's 30fps for NTSC, 25fps for PAL.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thats good, now are there any programs that can just turn the mpeg2 into vob w/o check the damn standard?
my cheap no name dvd player will play mpeg 1 and 2 files on a dvd burned as a data dvd, with no converting or headers just raw mpeg worth trying if u have a rw disc or cd, only some players do this and ive found that friends with posh brand name players cant use my discsbut its handy to pull back to pc if thats the case, worth trying before you start converting
Hello,
Besides using a file level player you might try ifoedit. I've never had much success with it. I'm not even sure it converts mpeg to vob. Keep looking and maybe you'll find something.
Kevin
P.S. Do a net search for "dvd author program - non standard" maybe you'll find something.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
File output issue from TMPEnc Author Works, VOBs -> single MPEG2
By aln688 in forum Video ConversionReplies: 4Last Post: 10th Apr 2010, 20:17 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52 -
Create DVD from several VOBs ?
By flash70 in forum DVD RippingReplies: 3Last Post: 8th Jun 2008, 09:51 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 18:01 -
How to Fit five VOBs onto one DVD?
By DeEp34 in forum Newbie / General discussionsReplies: 10Last Post: 14th Jul 2007, 19:42
