Does DVDLab ruin audio sync??
I had an encoded mpg in perfect sync but when I burnt it it was out of sync towards the end of the movie??
Maybe it is creating the vob's ifo's bup's out of sync? I burn with nero 6 could it be nero burning out of sync.
My HD is clean an defragmented so I know it is not that. Does anyone now what it is??
Generally authoring and burning don't create sync problems. More likely it was out of sync before, but didn't show up when playing. Bad frames? If you demuxed and changed the audio, then rejoined it, may have happened there.
There are plenty of threads here on audio sync problems. (And a sticky note, I believe.) Look around.
How to create an Audio-Only DVD in DVDLab Pro (IMPROVED)
By GordRocks in forum User guidesReplies: 26Last Post: 15th Jun 2023, 06:55 -
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
How to Author AC3 5.1 Channel Audio Only DVD Using DVDLab Pro 2
By Hittz in forum User guidesReplies: 10Last Post: 3rd Apr 2011, 00:05 -
DVDLab Audio Playback
By alhall in forum Authoring (DVD)Replies: 1Last Post: 26th May 2008, 09:00 -
How to create an Audio-Only DVD in DVDLab Pro (PART 1)
By GordRocks in forum User guidesReplies: 28Last Post: 7th Oct 2007, 00:53
