hi all
i have a avi filewhich is a xvid i convert it to dvd using TMPGEnc, i have followed the guides but 2 things are happening. first when i get to the end the file size is way over 4gb and no matter how much a change the settings (example video bitrate) i can not get it below 4gb. the orignal file is only 700mb.
Secondly but probably not as important as i have to fix the above problem first, when i just tested it so see if it would encode it appreared to have no sound.
Any suggestions would be great
Thanks all
Chris
Check the XVID with AVIcodec. It may have MP3 VBR sound.
I started using 'TheFilmMachine' for XVID to DVD conversion. Very easy to use and has worked perfectly so far. -
i have checked it and it says
Audio : 86 MB, 130 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
does this mean it has mp3 vbr sound???
if so what do i need to do??
Chris
Dvd to .avi audio problem
By gartzo in forum Video ConversionReplies: 5Last Post: 21st Feb 2012, 10:04 -
DVD to .avi problem
By poir420 in forum Newbie / General discussionsReplies: 6Last Post: 16th Nov 2010, 18:12 -
Downloaded AVI to DVD problem
By karlh10 in forum Video ConversionReplies: 6Last Post: 5th Aug 2008, 15:55 -
Avi to DVD problem
By slipknotkod in forum Video ConversionReplies: 2Last Post: 30th Jul 2008, 02:57 -
dvd to avi problem
By hobmob in forum DVD RippingReplies: 7Last Post: 2nd Sep 2007, 18:40
