if i put my cpr at 1600 and my video birate at 2000 will i get a good quality picture? or shoul one of these numbers be higher..... i am trying to get 3 to 4 hour of time on a disk (dvd) any onfo would be great...........
Results 1 to 11 of 11
Hello,
I read a post that suggested half d1 (352x240 ntsc) and 3500 bitrate for 3-4 hours of dvd video. I can give you the post if you want. I haven't tried it myself but you could test it.
Also, the 2000 spec I think is for svcd. Programs might not recognize it.
yes, please can you post that mesage....so my birate should be at 3500 and my cpr at what number exactly.........sorry for being a little slow b ut i am new to this and learning.
go low on resolution, BUT keep as high as you can the bitrate....
go for a half D1 and the highest resolution you can -
To get 3 hours on a disk the video bitrate should be 3100, to get 4 hours 2300. You better use 1/2 DVD res at those rates...352x480 NTSC, 352x576 PAL.
What's cpr? Cardio Pulmonary Resuscitation?"Art is making something out of nothing and selling it." - Frank Zappa -
Hello,
https://www.videohelp.com/forum/viewtopic.php?t=230312
That's the link. The post is by Richard_P I think. I hope this helps.
I record a couple of TV shows and go with 4 hours on a DVD, and my standard settings are 352x480 frame size, 2410/500/9668 (avg/min/max) VBR and 128k for audio.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
sacajaweeda, I though your audio had to be 224 min and your audio could drop below, something like, 1800, 2000 or so for DVD.Originally Posted by sacajaweeda
btw... I miss your old avatar -
224 audio bitrate is required for VCD but the DVD spec is pretty much wide open as long as the sample rate is 44k. My minimum bitrate (VBR) for video is usually 2000 for stuff I might share with other people, but for mundane crap like TV shows I record, the only players I really care if it plays on are my own, so I go with 500. To be honest though, I haven't had any problems with those discs in any of the players I've ever tried them in.
Agree on the avatar....I don't like this one much either so I'm gonna switch it back
48 KHz for DVD.Originally Posted by sacajaweeda"Art is making something out of nothing and selling it." - Frank Zappa
That's the ticket.
Audio Birate Difference please help
By skorpinok in forum AudioReplies: 3Last Post: 30th Aug 2010, 13:34 -
mkv/mp4 720/1080p birate info
By ckamc in forum Newbie / General discussionsReplies: 7Last Post: 29th Feb 2008, 07:55
