Okay, I'm totally stoked 'cause this is my first time going from AVI to DVD!! woo-hoo
So here's what happened. I followed a guide that had TMPGenc do all the encoding, and then IFOEdit to make that output into DVD burnable form (multiplex?) (incorrect terminology I'm sure, sry, still learning).
So here's my problem: On the computer the output looks great! When I put the DVD into my DVD player, on the lower half of the screen is a solid green bar. On the top half the video is there but it looks interlaced(??) [it looks like there are lines missing/fuzzish... don't know exactly how to describe it. There are elements of the movie there obviously]
Does anyone know what went wrong?
Thanks!
Hello,
What was the file type that came from tmpgenc? If it was mpeg just use a dvd authoring program to burn it. I don't have experience with ifoedit so I don't know if that was where you made any mistakes (if any).
If you still have the file from tmpgenc I'd use that and try again. Practice doesn't make perfect but without it you'll be lost.
Kevin
Good luck, stick to it and you'll find something that will work.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
It ended up being like an mp2 and mXX, I forget, but I was told to use the IFOEdit to convert those files into the whold VIDEO_TS shtuff so I could have Nero burn it.
I don't think it's the output files, or shtuff, I'm thinking maybe it's a setting in TMPGenc or maybe a bad Codec or something? I'm using KOELI's XViD codec...
Any thoughts or help would be muchly appreciated. -
Hello,
I believe it would have been .mp2 (audio) and .m2v (mpeg 2 video). If so those two files can be muxed (mixed) into a .mpg file that can be read by a dvd authoring program that would be easier than ifoedit.
The video_ts "stuff" is where the .vob files go that make up a dvd.
Yoda - Yes, those are the two files. Do you have any suggestions for a program to MUX those two files instead of using IFOEdit?
(Maybe that is what caused my weird greeness... however it still doesn't make sense why the DVD worked on my PC and not on the player. I don't want to think that my DVD player sucks
Hello,
The computer has a TON of codecs installed so almost anything will play. DVD players are very strict (even ones that will play newer formats).
My suggestion would be to use TMPGENC and load the .mp2 and .m2v files into the project wizard (file, wizard). put the audio in the audio and the video in the video. Then from there (make sure you use the dvd ntsc (for US) option first. Follow the rest of the steps and you SHOULD get a merged .mpg file that will work in any dvd authoring program.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
XviD Encoded videos present distorted bar at the bottom
By deadp0et in forum Video ConversionReplies: 11Last Post: 4th Jul 2015, 09:45 -
Green Bar at bottom problem solved!
By DeniseAck in forum Capturing and VCRReplies: 0Last Post: 9th Aug 2011, 19:19 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 22:29 -
FLV to DVD, Bottom half stretches?
By Motadur in forum Video ConversionReplies: 3Last Post: 14th May 2008, 14:50 -
Green bar on bottom and right side of divx movie
By gthorley in forum Software PlayingReplies: 2Last Post: 19th Aug 2007, 15:39
