In "Environmental Settings", the Cache Setting is used for the VBR and is at 4GB as default. After ripping a movie, I don't have anywhere near 4 gigs. Does mean I need to lower the setting? If I do, do I lower it to the current space available on my HD or lower it to current HD space available minus the projected output file size?
Second question: how much space is needed for TMPG's temporary file? Do I need less, more, or about the same as output file size? I have two drives and one of the has about 900 megs free. I figure if I put the temp file over there, it frees up some space for output file in the other drive.
Results 1 to 1 of 1
not move the file tmp dir to upload folder
By velayudham in forum ffmpegX general discussionReplies: 2Last Post: 19th Jan 2012, 17:32 -
How to stop Ripbot from auto deleating the temp file?
By cal_tony in forum Video ConversionReplies: 0Last Post: 5th Feb 2010, 13:36 -
Tmpgenc - Save multipass VBR analyze results in the cache-What does it do ?
By davexnet in forum Video ConversionReplies: 8Last Post: 15th Jan 2009, 15:59 -
Xvid3PSP Problem: File Could not Be opened (C:\Temp\preview.avs, line 6)
By Dschultz in forum Blu-ray RippingReplies: 20Last Post: 10th Oct 2008, 09:08 -
Video and audio files are split in temp. file
By SSH1968 in forum Newbie / General discussionsReplies: 9Last Post: 14th May 2007, 17:50
