i have thetransporter movie in divx. im trying to convert it to mpg so that i can later author it and then burn it to a dvd+r. i used tmpgenc xpress but the aspect ratio isnt the same. it seems to have stretched it out vertically a little bit. ive also tried using other programs too like thefilmmachine etc....but these ones dont tell me how big the resulting mpg file is so that it can fit the mpg to a dvd+r. ive tried the trial versian of winavi it is exactly what im looking for. it fits the mpg file so that it will later fit onto a dvd+r and it keeps the aspect ratio....however the trial version has watermarks......so right now im asking if anybody knows any other good programs out there that can do the job for me. i can only use trial versions and freeware becuase im cheap..lol...
using just the normal TMPGenc right? where do i select fullscreen? when i open TMPGenc the first screen is the project wizard....what do i select? under dvd, ntcs or ntcs 16:9.......i am really frustrated right now......and i appreciate any help.....if you could explain it step by step it would be easier.
If I explained it step by step then I might as well call it a guide. Here's one ready made for you.Originally Posted by asdf"Art is making something out of nothing and selling it." - Frank Zappa
ok...thetransformer is in pal format....so yesterday night i changed the settings to pal 16:9 in tmpgenc xpress.....but no help...its even worse.....in the meantime ill try the guide
Divx Aspect Ratio Change??
By gdb in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2011, 07:34 -
Vob2Mpg Pro problem with extracted MPG aspect ratio
By Spoon_Lover in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 1st Oct 2010, 04:20 -
How do I create a DIVX w/correct aspect ratio
By peggypwr1 in forum Newbie / General discussionsReplies: 5Last Post: 3rd Oct 2008, 10:16 -
Odd Aspect Ratio Problem in mpg files
By nerys in forum EditingReplies: 10Last Post: 14th Nov 2007, 13:45 -
Changing an aspect ratio on DIVX
By diablo_jones999 in forum Video ConversionReplies: 13Last Post: 29th May 2007, 12:53
