I need a command that I would call "Dissove Folders".
Imagine a folder full of sub folders. Now I want to get rid of the sub folders and have all of the contents togethor in the folder. I don't see any quick way to do this. I would need to open up two instances of this folder and then one by one open the sub folders and drag the contents into the main folder.
Currently I am trying to clean up my Start Menu. Every program puts it's own useless folder full of junk in my start menu. It's a big mess. I want to make all those sub folders vanish and then I will organize the items by type and delete all the useless stuff and just keep the programs themselves. (If I ever need any of that other junk it is still in my programs folder since the Start Menu only contains shortcuts).
This is only one example of a use for the Dissolve Folders Idea. Is there any such command or a utility to do this?
I would do a *.* search on the parent & sub folders then sort the results by location , cut and paste everything except stuff in the parent folder to the parent folder
Good suggestion. It's better than the way I've been doing it. I still think my "Dissolve Folders" idea would be even better.
Avisynth. Stumbled audion while Dissolve()
By egochnpp in forum EditingReplies: 4Last Post: 4th Feb 2012, 08:26 -
How do I lap dissolve with Cyberlink Power Director
By tonycopple in forum EditingReplies: 1Last Post: 27th Aug 2011, 20:05 -
Low Quality on Dissolve Transition with Photos
By mattgx in forum EditingReplies: 22Last Post: 26th Jun 2009, 20:58 -
cut vs dissolve ...
By perik in forum EditingReplies: 3Last Post: 28th Dec 2008, 16:53 -
Edge artifacts noise caused by transitions/dissolve effects.
By baculus in forum EditingReplies: 6Last Post: 25th Jun 2007, 18:07
