  1. Member shelbyGT's Avatar
    Oct 2003
    Kansas City, KS
    Okay, I searched these forums a bit and found some not as helpful info as I needed.
    First, I just installed winfast 2000 deluxe. I got the card installed, let the install do its thing, and I think I have the wires connected right (audio out on capture card to line-in on sound blaster card).
    I can bring up the PVR just fine and SEE the television station... but I get no audio at all. I get no audio with PVR and no audio in winamp.... My computer is completely silent!!!
    I have the "digital output only" selected on my sound card going to my boston acoustic speakers. What did I do wrong here? How do I regain sound?
    update - well, i tried unhooking my speakers and just plugging in headphones and then deselecting "digital out", and I get sound now. My question is how do I enable digital out so my other speakers can work?
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Not sure about the digital out, I think that's just what your soundcard ouputs to your spekers. Has nothing to do with why your sound doesn't work.....Anyhow you need to enable the input that you used on your soundcard. Open up the soundcard configuration software and enable whichever one your using (aux, line-in or microphone). If it is enabled make sure the sound is not turned all the way down.
