I'm kinda new to creating DVD's so go easy on me. I recently started encoding only the video stream from tmpenc ( I heard it's better for audio quality), and use virtual dub to extract audio.
My problem is I want to remove the intro, and credits from the movie stream, and trim the audio to match, so the audio length matches the video length, and it's in sync. I currently use easy video splitter for cutting out the intro and credits, but I'm not sure how to do the same to the audio.
Is there a program that can load both the audio, and video stream separatley, so when you trim parts it does both right away? Any help is appreciated,
Use tmpgenc dvd author,it also lets you cut out parts you dont want.
Thx for the tip. I found another way to do it. I use the Mpeg tools in tmpenc to remux the video, and audio stream together, and then cut-out the credits. Hope this helps anyone with the same problem.
i have a video that has 2 audio streams..what does that mean?
By vincy in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2012, 06:45 -
Can't Mux audio & video streams to MP4 without a problem
By spycam in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2010, 17:49 -
Trimming the audio to go along with the video cuts in avisynth?
By mt123 in forum Newbie / General discussionsReplies: 0Last Post: 10th Jan 2010, 04:23 -
Use to author from separate audio and video streams?
By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 14th Jul 2009, 06:41 -
Video with 2 Audio Streams TO mpeg1 with 1 audio stream
By Xenogear900 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 20:00
