Results 1 to 9 of 9
  1. Hi Guys !
    Im looking for some kind of card that support me to add effect and create subtitel , like pinnacle's some card can allow me to add live effect to my subtitel , or just add effect like fade in and fade out to my subtitel in movies .
    And the card's can help me make motions menu , author my dvd with great menus .
    Do sombody can show me some ?
  2. First of all, you'll get a lot more help if you post with proper grammar and spelling, form coherent thoughts, and not post a second message if nobody has responded. It is not entirely clear what you want.
    What capture card you use is irrelevant. Editing video is not a function of the capture card, but a function of video editing software.
    There are a number of products designed to do this. You'll find plenty at your local computer store; Ulead makes a number of them including the popular Ulead VideoStudio.
    Some capture cards MAY come with video editing software included, but probably only a limited version.
  3. Sorry for my unclear post !
    All i want now is which is hardware card that support me to add real time - special effec to my movies , like fade in, fade out subtitel, or like hollywood fx effect .
    And , maybe its like snazzi's AV.DV card ?
    Help me
    Because i want to create a dvd with some kind of kool effect on the movie , like some comercial scene, picture, or text
    Apr 2002
    Oskeeweewee Ontario
    Usually, the three big names for small people (like us), are Pinnacle, Matrox, Canopus..
    On board codecs allow the hardware to speed up the process..
    Go to the left, and look at the Capture tools...
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If you want to do this live, then you are looking for a card with Gnelocking capabilities and enough grunt to take the live feed in, processes it in realtime, and output the finished clip with no interruption.
    If this is what you are after, you need one of these http://newtek.com/products/vt/info/index.html
    This is serious kit though - look at the system specs required.
  6. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    For some reason I have the feeling that this is a bit more than what din4na was expecting
    - John "FulciLives" Coleman
    Apr 2004
    Miskatonic U
    He wants "to add real time - special effec to my movies , like fade in, fade out subtitel, or like hollywood fx effect "
    I can't think of a better toy
  8. din4na:
    If you want to create a DVD then you do not need something capable of performing effects in real-time.
    If you were producing live television shows, that would be different; and also very much out of the scope of this forum, I think..
