Results 1 to 11 of 11
  1. I've been using several programs to backup my DVDs. For me, aside their pros and cons of using the program, their quality is almost same (I guess I am not that sensitive) when viewed on regular TV.
    The question is what percentage of compression is acceptable when converting dual layer to one DVD-R?
    I usually try to go with over 80% of original size and if the movie still does not fit in, I just use two DVD-Rs. What about you?
    Thanks.
    IMAGE SIG DELETED
    You are in breach of the forum rules and are being issued with a formal warning.
    NO ADVERTISING
    Thankyou
    / Moderator offline
  2. Originally Posted by jaeshin
    Quality is such a highly subjective issue, and the results of DVD transcoding vary according to the tool used and the type of material, that there is no correct answer to this question. If you are happy with the results thats all that really matters.
  3. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    can I get in before the disagreements start?
    basically you will get anything from 50% to 99.99% here so this is a pointless question really
    it's best you do a few tests on a DVD-RW and try it for yourself as there a a few factors that will determine what's good for you such as perception of quality, original bitrate, quality of transfer, viewing equipment etc
    I still have a feeling some will still want to say whatever values they are happy with but they mean nothing to me and most others
    :EDIT:, lol no I can't get in quick enough though I bet I started typing first
  4. Member 888888's Avatar
    Jan 2004
    Turdistan
    I never use two discs. I do as much as DVD Shrink can handle. I cut out more extras if necessary. Movies at 60% look worse but are definitely acceptable.
  5. Member Treebeard's Avatar
    Aug 2002
    I dont like it to go below 70% if possible.
  6. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    let me save this thread a lot of time and give sugardaddy his info he wants now
    reply 5 - 85%
    reply 6 - 75%
    reply 7 - 99.99%
    reply 8 - 65%
    reply 9 - 50%
    reply 10 - 100%
    reply 11 - 70
    etc, etc, etc
    morale of this post, everyone's opinion of the value will probably be different along with the tools, their opinion of the comparision between the original/backup and could possibly range right up at 99.9% down to 0.01%
    p.s. here is a very similar thread that may give you some idea sugardaddy
    https://www.videohelp.com/forum/viewtopic.php?t=212885
  7. Another consideration is the bitrate of the movie. A higher bitrate will often allow for greater compression with a transcoder while maintaining acceptable results. However, what's considered acceptable varies from user to user. In the end, you must make the final determination.
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  8. Originally Posted by jaeshin
    Thanks.
    Or does he really care about the answer or just want people to click on his banner link (I guess referer id 7243041) gets him something.
    Apr 2004
    While I agree quality is subjective, I do find it interesting to see what other's think an acceptable level of compression is. Yes, yes, we all know the obvious "it depends on the material" and "everyone's eyes are different" responses, but you CAN get some sort of estimation for a general concensus of usable compression with a question like this. I don't see why this bothers some folks, but whatever.
    I try to never go below 80% with dvd shrink. If a movie requires more compression, I'll split it to two discs with dvd fab (or is it fab dvd?). I tried dvd rebuilder because I'd heard it produced better results at the same compression as dvd shrink, but I was using one of the free encoders (not cce), and I actually thought it looked worse, at least on the movie I was using. I have read good things about dvd2one, so I might try that next time I have to backup a main movie only (it doesn't seem like a good option for full-disc backups).
  10. When too many compression is needed to shrink a movie in one DVD, first I test it by doing it and burning it in a rewritable. Depending on the result, I keep it, or split the movie in two DVDs.
    Nov 2003
    Midlothian,VA
    i shrink as much as i can. my eyesight sucks but my ears work great---as long as i get a 5.1 or a DTS audio track, i am happy!!!!!
