I want to burn anime videos (.avi format) to CD or DVD. Someone suggested to convert the .avi to .mpeg or .mpg first. Is it better that way??
And is there the best way to burn a video?
How to burn the best qualilty is a wide open question. My answer is to start w/t the best possible source. you will have to convert to mpg if you want to go to cd or dvd. just read the conversion guide on going from avi to DVD. its to your left <----
If you just want to play them back on a computer, then you can just burn them straight as a data disk (copy them onto the disk unchanged). This will give you the best quality as it doesn't require re-encoding.
If you want to play them back on a set-top box then it may require re-encoding, although some may be able to play them if they are just copied as data disks. First, check wheather or not your desired playback machine can play them as is, copied straight to disk. Then check out the guides on how to convert if it doesn't.
-Suntan -
I want to burn them to DVDs and actually see them with the video player.
My friend said if I convert .avi to .mpg first, the quality would be better. Is it right? -
No, it would not be better. It is not really possible to make something better, in a sense. You can adjust it, with filters and such, and mask some of the mistakes, but it will not be truly better, in some cases it make be slightly worse.Originally Posted by Grey land
But if you are going to do a quick convert from avi to mpg, no it will not look better.Blah, blah, blah -
There is plenty of information on Forum to help with that.
burn dvd9 to dvd5 and still keep 80 to 100% video quality
By vance43211 in forum User guidesReplies: 35Last Post: 6th Dec 2010, 09:40 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
Getting a better quality burn
By brado09 in forum DVD RippingReplies: 6Last Post: 24th Apr 2009, 11:59 -
Check quality of burn
By amerifax in forum DVD RippingReplies: 8Last Post: 18th Mar 2009, 21:34 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38
