Hello Major,
I've a .AVI that i can use as source in ffmpegx with my Powerbook, but impossible to use on a G5.
The error (only on the G5):
**ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
Here's my 2 configurations:
1) PowerBook Titanium 867Mhz 768Mo 10.3.4
ffmpegx 0.0.9m with the new mencoder/mplayer/libs, mpeg2enc
2) G5 2x1,8 Ghz 1.5Gb 10.3.3
ffmpegx 0.0.9m (installed with the same downloaded files!)
On the PowerBook, when i drag and drop the source file (a divx) on the ffmpegx icon, i have the video size and the time correctly detected. I choose the DVD preset, check&load the subtitle, check Decode with mplayer (for the subtitle). So everythings works very well on the PowerBook.
On the G5, when i drag and drop the source file (a divx) on the ffmpegx icon, I DON'T have the video size and the time correctly detected
So i use the same preset that the PowerBook, and check DUAL cpu. When i hit encode, it failed:
Encoding started on Thu Jul 22 13:27:01 CEST 2004
mkfifo: stream.yuv: Permission denied
-f 5 -b 4000 -q 3 -B 260 -V 230 -a 2
/Applications/ffmpegX.app//Contents/Resources/mencvcdX: line 200: stream.yuv: No such file or directory
-F 1
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
MPlayer dev-CVS-040718-22:40-3.3 (C) 2000-2004 MPlayer Team
AltiVec found
CPU: PowerPC
Is it maybe a problem of permission?
On my PowerBook:
Encoding started on Thu Jul 22 13:26:42 CEST 2004
-F 1
AltiVec found
CPU: PowerPC
PS: By the way, it's impossible to hide ffmpegx application. Only possible with the ffmpegx icon in the dock.
Thanks in advance,
Toche
Ti 867 MHz - 768 Mo - Airport - 10.3.4
ffmpegX 0.0.9m [REG]
Major,
It's a permission problem. I'm encoding right now with an admin session.
The file created is "stream.yuv" on the "top level" of the hard disk.
Is it possible to create that file on the current user folder?
Thank, thank, thank you,
TocheTi 867 MHz - 768 Mo - Airport - 10.3.4
MeGui: error in encoding: "x264.exe:unrecognized option --progress"
By Julllie in forum Video ConversionReplies: 4Last Post: 30th Apr 2011, 05:21 -
Post examples of scenes with "fade" in them for encoding w/ x264
By vhelp in forum Video ConversionReplies: 1Last Post: 8th Sep 2009, 02:27 -
Setting "top field first" flag without re-encoding/re-authoring
By Miles in forum Authoring (DVD)Replies: 2Last Post: 16th Jan 2009, 06:15 -
Which software do "DVDx" with batch encoding modes pls?
By amdk62 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jun 2007, 05:39 -
encoding from WMV to .avi usin "decode with QT", audio fails
By fury420 in forum ffmpegX general discussionReplies: 3Last Post: 18th Jun 2007, 00:21
