I've noticed lately that Windows Explorer keeps getting errors and shutting down/restarting fairly frequently. It isn't really hurting anything but its annoying and I'd like to find out what the problem is. I've had it happen a few times in the past when memory needed a refreshing, mainly when running Edonkey, but this is happening even when I'm not running Edonkey now. I did download critical updates a few days ago, 5 patches I believe and I'm wondering if thats the cause of it. anyone else had such problems after these latest critical updates?
Results 1 to 9 of 9
No problems here since updating. Matter of fact I've only had a handful of crashes since getting XP iun November. I think most of them were from software other than MS. How about a little more info such as what the error is, you could also try the MS knowledge base. Do a search for the error. Possibly a virus?
Just to clarify is it Windows Explorer or Internet Explorer, they are two seperate programs, at least in name. -
I was having similar problems about 6 months back on my work machine...I wrote down the errors, visited the MS Knowledge base and there they were with directions on how to fix.Originally Posted by Poppa_Meth
Tim -
its Windows Explorer. I'll check the MS database as soon as I can. I'll copy down the error report next time I run into the problem. All it says is Explorer has encountered a problem and needs to close but I"ll get more in depth info when I get home.
I also have been getting the Windows Explorer has encountered a problem and needs to close error.
I'm running spybot, and adaware so I doubt its spyware.
Sometimes they don't get everything.
You might also try hijack this -
So far no more problems so I'll hold off on Hijak This since I hear it can have some major side effects if you aren't careful with it.
Computer keeps shutting off
By black cloud in forum ComputerReplies: 18Last Post: 2nd Aug 2011, 21:54 -
Laptop shutting down...
By alintatoc in forum ComputerReplies: 7Last Post: 6th Feb 2010, 14:31 -
Computer keeps shutting down
By didikai in forum Newbie / General discussionsReplies: 22Last Post: 31st Aug 2008, 08:24 -
HV20 Shutting Down
By Seavemeyer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 22nd Dec 2007, 22:57 -
Nero Keeps Shutting Down
By DuBsTaR in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2007, 11:41
