  1. I own a Hauppauge video capture card, and it was ok for experiment purposes, but now that I think I understand a little more of the proccess of video capture, I want to purchase a better one without having to mortgage my house to do it!
    I need advice from you guys, what card is a good one for having a good video capture?
    Thanks in advance.
  2. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Canopus ADVC-100, -50, or -1394 depending on how serious you are.
  3. Originally Posted by rallynavvie
    Maybe you can help me out here. I inquired in another thread I started about DV. What exactly is the ain advantage of an A -> D converter such as the Canpus units and others. Is it really that much better than my analog cap card? If it is merely sync issues, I got that licked. There has to be something more....
  4. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    There are some quality differences and you're also freeing up system resources if you run a FireWire one. Which card have you got?
  5. I too have an analog capture device (ADSTech vs your Happauge) .... and I wanted some better quality. Found out that I could run analog thru camcorder (built in TBC) and then out thru DV (A/V --> DV) (DV in on computer via 1394)
    Works awesome.... video capture seems a tad crisper than directly into PC via MPEG Hware encoder.
  6. Originally Posted by rallynavvie
    Was this for me? I bought an Adaptec Fire connect 4300. It was the only one in the BX. A IEEE 1394 card is an IEEE 1394 card right?
  7. Originally Posted by fmctm1sw
    Hmmm, guess not... https://www.videohelp.com/capturecards.php?CaptureCard=&dv=1&searchconnection=Any&price...&Search=Search
    Mine worked fine.
