Analog videotape has timing and synch problems due to the physical mechanics of the system. Factors such as the rotating tape head, pinch rollers and capstan (causing a very small amount of tape stretch), temperature and humidity... these all have a detrimental effect on precise timing. It has nothing to do with how new a tape is, other than to say a poorly recorded old worn out tape will tend to have even more serious timing issues than a newer one will. In the professional broadcast and editing world, full frame TBC's are a necessity for all analog videotape output.
The TBC's in consumer VCR's and DVD recorders (and even in devices like the Canopus ADVC-300) are Line TBC's and do not sample and correct the timing of the entire frame (two fields). That's why they do not defeat Macrovision or other tape copy protection signals.
A full frame TBC may fix your capturing problem because it will completely strip, correct and replace the timing synch signal frame by frame.
Results 61 to 62 of 62
Originally Posted by gshelley61
I'm saving this one.Want my help? Ask here! (not via PM!)
Sony dvd recorder model RDR-GX300 cannot play/record discs
By hdubya in forum DVD & Blu-ray RecordersReplies: 1Last Post: 26th Aug 2011, 02:40 -
Is Sony RDR-HX720 compatible with Sony HT-SS2300
By abdul_sma in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th Nov 2008, 09:14 -
Sony RDR-GX300 DVD Recorder can't record channels 200+?
By showmi in forum DVD & Blu-ray RecordersReplies: 2Last Post: 8th Jul 2008, 14:49 -
Sony RDR-HX900
By munish1000 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Apr 2008, 18:21 -
Sony RDR GX7
By Macdon22shippTWO in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Sep 2007, 11:55
