hi, I have TMPGEnc 3.0 XPress, I check the filters but there is no brightness. Can someone show me how to adjust the brightness, is there a brightness filter that I can download? Please help, thanks!
I think there's a filter option for gamma/brightness. I'll check when I get home.
@Askformore
Under the advance tab, double click the custom color correction, then click the add button. Adjust the setting. Use a small clip to test out the settings before you go ahead with the full movie. -
hi, can you tell me where the advance tab is? because I open the program, but couldn't find the advance tab anywhere, thanks
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
