  1. Ok, one more time...
    A movie plays fine on my computer but audio is out of synch when burned to cd-r with nero. Both video and audio are fine on computer. Movie is SVCD and burned as VCD with nero. It is .MPG extension. Nero tells me that my video is mpeg2 instead of mpg1 and that it has to re-encode video with takes 30 minutes before burning. Ive nevr had this problem before. Whats happening?
    Apr 2004
    Hudson, Florida
    When you use TMPGEnc to make the MPEG2 don't let it extract the .mpa from the movie. Extract a WAV from your movie and use that as the audio input when it asks for the video and audio files, all should be good now.
  3. the movie wont open using tmpgcodec. it says cannot open or unsupported. I have changed the settings in option<environmental settings and still no luck. What else can i do? what other settings should i try?
