Hi,
I got a problem with converting audio from avi clips.
I have 1 divx file and one xvid file.
They both have MPEG1 Layer 3 audio (says GSpot)
I use TMPGenc Plus and/or TMPGenc DVD Source Creator to convert my stuff to a dvd format so that Maestro understands'm.
But both programs do not extract the audio.
Well they think they are, but in the end the file contains nothing but pure silence.
Now I don't have a clue of where to start searching for why this is happening.. stripping the audio from the video with virtualdub and compressing that to some usable format with TMPGenc Plus seems to work in some cases, but not all...
Can somebody help me out here?
Ok load up your avi file in virtualdubmod (it's what I use, but vdub will probably be the same).
Go to "Streams"
Then to "Streams list"
Right click the stream, select "full processing mode"
Right click again, select "compression"
Select "No compression (PSM)"
Click "Save WAV"
Then save as wav file
Use this wav file as audio source in Tmpgenc
I hope this works for you, there is probably an easier way, I just don't know it.
edit-Sorry, didn't read the part where you already tried this.Blah, blah, blah -
look at [url]http://members.home.nl/thefilmmachine/.
Download the program. It's for free
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 23rd Feb 2008, 23:35 -
Audio synch issues when converting to XviD or DivX
By baduncan in forum Video ConversionReplies: 3Last Post: 15th Dec 2007, 13:25 -
The last vts file screws up why?converting xvids?using svcd2dvd!!!
By hacksawman in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 8th Oct 2007, 16:30 -
Problem Divx's & Xvids
By ramses505 in forum Video ConversionReplies: 3Last Post: 8th Oct 2007, 09:39 -
Converting Video/Audio TS folders to DivX etc.
By supermac in forum MacReplies: 7Last Post: 18th Jul 2007, 08:58
