I am trying to convert old 8mm or maybe it is 16mm film (havent seen it yet) onto a DVD. I mean i am talking the old stuff before sound was recorded. I know i will have access to a projector and dont know if i can capture it with a DV-camcorder or if there is somewhere i can have it done that is not really expensive. Either way any help or ideas would be greatly appreciated. Thanks
Here's what I do...
Get the 8mm film telecined and transferred to MiniDV.
Get a MiniDv camcorder with Firewire output.
Get a Firewire card for your computer (unless it already has Firewire inputs).
Search for WinDV and the Panasonic DV codecs. Install both.
Capture the telecined film to you computer via Firewire link with your camcorder.
Re-encode the captured footage using the Huff YUV codec.
Once the footage is encoded as YUV you can then do inverse-telecine using the Telecide filter in AVISynth on the footage to get the progressive frames back.
Once you have progressive frames back then edit the footage preserving the 23.976 fps frame rate.
Encode the edited footage to MPEG as progressive video.
Author to DVD.
Kick back, have a beer, and say God is great.- Mike Young
My Clay Animations -
I rememebr discussing this a while back too. You may be able to project it onto a screen and just videotape it with your camcorder. I think there are other ways to do it as well.
True, you could just tape it on a camcorder, but a telecine would yield better results. I doubt that it's feasible to recover progressive frames from film that is taped on a camcorder. If you are really serious about transferring the film well, you'll want those progressive frames back.
If you go with a telecine, try a search for "telecine" and "minidv". You should be able to find a place that will transfer it for you.- Mike Young
My Clay Animations
8mm film to dvd and which video transfer system to use
By krlorenz in forum RestorationReplies: 16Last Post: 28th Jul 2014, 17:12 -
Telecine Machine for 8mm film super 8 film transfer to dvd
By igotregister in forum Capturing and VCRReplies: 5Last Post: 2nd Feb 2009, 16:50 -
Can't transfer 8mm tapes to DVD-RW, advice please
By nathanaa in forum Newbie / General discussionsReplies: 9Last Post: 11th Dec 2008, 14:18 -
8mm film to DVD ????
By StuR in forum RestorationReplies: 31Last Post: 29th Nov 2007, 10:21 -
Top quality professional transfer of 8mm and Super 8mm film
By cosmichippo in forum Video ConversionReplies: 75Last Post: 25th Jul 2007, 22:28
