  1. I downloaded a TS_file off bittorrent. How do I view a TS file? can i burn it? if so, to a dvd-r or cd-r? thanks!
  2. Member holistic's Avatar
    May 2001
    here & there
    TS off torrent ........google returns ...... wait for it ........... Telesync
    Telesync
    One of the multiple terms used by movie pirates to describe the source material that was used to make a bootlegged pirate copy, normally distributed in VideoCD, SVCD or DivX format.
    http://www.afterdawn.com/glossary/terms/telesync.cfm
  3. not TS but TS_file
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    as in "nameoffile.ts" ?
    it may be a transport stream movie -- some are HD even ...
    windvd will play those ...
    you can convert it to dvd - yes ... but depends what it really is and what resolution etc in how you go about doing it ..
    procoder 2 will directly accept ts files and convert them ..
    other encoders may require a extra step or two ..
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    if it is "TS_FILE" as you wrote ..
    it is most likly warez and holistic's answer is correct
