Hello, so sorry if this is answered but I simply can't find the answer.
I have a Sony Handycam Digital 8 camera and FINALLY put FIREWIRE on my computer (add on card) and went to winXPNow I'm set!
I also have NERO for burning DVDs and started playing with Microsoft Movie Maker (people seem to like it and it is free).
What I can't seem to figure out is how to get from the "file" to DVD (Video_ts) format? WMM2 (windows movie maker 2) appears to let you either create AVI files or WMA files that contain both the video and audio. The AVI file gets created when you choose the BEST quality which is what you would want for a DVD, ok......
So how do I get from AVI to DVD? Can you do it with what I have? Do I need something else to supliment what I have? People throw out all kinds of other software (RecordNOW, SONIC, Roxio, etc) but I really want the cleanest way using Nero (if possible) without having to install/use all kinds of other STUFF.
Thanks so much
Alan
Following this guide: https://www.videohelp.com/guides.php?guideid=566
You will need these tools:
TMPGEnc, TMPGEnc DVD Author, WinDV
You will also need Panasonic DV codec installed.
If you already have some AVI files you could covert them to MPEG2 using TMPGEnc. Then, author your DVD with TMPGEnc DVD Author. When you are done, just burn the DVD. Check the guides for details https://www.videohelp.com/guides -
Thanks so much for the reply and I will go through the document. However I did make some progress.....
What I was after was a nice clean easy way to do the capture to DVD without having to use 1/2 dozen "tools". I mentioned I have NERO and was hoping there was a way to do it with that which I just hadn't figured out.
This was the case.... Using NERO Vision you can capture and then using NERO Vision again you can simply use what you have captured and burn a DVD. You can either add all the fancy backgrounds and menues and titles if you want, or not. It does all the capture and converting and creating, etc to build the DVD structures.
Bad Vhs transfer in digital as source
By mammo1789 in forum RestorationReplies: 15Last Post: 4th Nov 2011, 21:04 -
Advise needed on managing digital video collection...
By nharikrishna in forum Capturing and VCRReplies: 2Last Post: 18th Jan 2011, 06:20 -
Problems Creating New Projects From .VRO/.VOB Source Disc
By RocknRollElitist in forum Video ConversionReplies: 0Last Post: 29th Oct 2010, 14:29 -
Creating DVD from Sony HD camcorder HDR SR11
By 1234567 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Mar 2010, 07:46 -
Creating a Pseudo 5.1 Mix from Stereo Source Using V.I.
By guns1inger in forum User guidesReplies: 13Last Post: 27th Jul 2009, 17:21
