i have been using a 118vob movie trailer on flaskmpeg but when it converts to avi its over 3gig in size
the picture quality is perfect but the size is massive
am i doing something wrong?
It looks like ur using uncompressed video. Ur not doing anything wrong.
Could you tell me the width and height of the video.
Do u want to minimise the filesize?? -
its 720 by 480 at 29.97frames converting to the same settings
so how can the file go from 118megs to over 3gigs -
Instead of converting the VOB to uncompressed AVI, you can use DVD2AVI and frameserve the VOB to TMPGEnc without taking up 3 gigs of disc space to do it.
Great way to go. See the GUIDES on how to use DVD2AVI, once you get it setup its super easy to use.
Why can't I convert an AVI file over 4 gig?
By danzautomatic in forum ffmpegX general discussionReplies: 3Last Post: 23rd Nov 2010, 08:59 -
Help Recovering a 29 gig AVI
By ReiverDemon in forum RestorationReplies: 11Last Post: 13th Dec 2009, 20:52 -
How do I reduce the file size of my 16 meg movie?
By Luckyword in forum MacReplies: 7Last Post: 20th May 2009, 17:53 -
How many 4.7 Gig DVDs may fit into 500 gig HDD?
By Bronx in forum ComputerReplies: 11Last Post: 24th Apr 2008, 09:40 -
Philips DVP5960 and 1.4 gig avi
By dude112 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 1st Dec 2007, 14:42
