Hi have a European DVD (PAL) I would like to copy using DVD Decryptor or DVD Shrinkand send off the copy to US friends.
Where do I set it has to be the NTSC system copy, it would otherwie not be playing on a US standalone DVD player, would it ??
Thanks.
No DVD ripper or compression program can change the TV system. They simply copy what's there. PAL would remain PAL. Check with your friends,their players are probably capable of playing PAL disks. Most non-major brand DVD players do PAL to NTSC conversion by default and vise versa.
Sony or Toshiba may not do PAL to NTSC conversion but virtually every other brand does.
Ripping and compression should make the disk region free. -
Thank you wulf109.
They do have a SONY !
How to convert to NTSC then ??
Thank you. -
Look in the All Guides Section on the left...
How To category
Prepare for some work.....
Better for them to get a new cheap dvd player that will take pal disks..Not bothered by small problems...
Spend a night alone with a mosquito
Good setup to copy NTSC tapes to DVD in Europe?
By Baree in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2012, 13:01 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
Copy NTSC video tape onto a DVD-R (based inUK)
By nacnud23 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Nov 2008, 06:30 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31
