Lite-On AllWrite LVW-5005 DVD/CD Recorder
Is this a good unit for a novice to buy that wants something real easy to use with good quality, is it dependable, the price at around $299 seems good, is there any other good quality easy to use ones that I'd be better off with.
I want to copy from my SVHS and Hi 8 to hand out in dvd format.
I also want to copy from cable TV
Ease of use and quality is very important...
http://www.amazon.com/exec/obidos/tg/detail/-/B0001DYXOU/002-2779056-4705609?v=glance
Poker TV Guide http://www.go-poker.com
JVC DRM10S for $297:
http://www.ecost.com/ecost/ecsplash/shop/detail.asp?dpno=400096 -
I'd only get the LiteON if you want to hack it for MV removal.
By far, the JVC is better.Want my help? Ask here! (not via PM!)
I recently bought a LiteOn LVW5005 from CompUSA. I like the fact that I can record on DVD+RW/+R, DVD-RW/-R, and CD-RW/-R. I already had a ton of blank DVD+R's and DVD+RW's. I have three Tivo's and being able to record Video CD's directly from the LVW5005 is good for the shows I have on Tivo that I want to keep but not use a DVD disk. Works great for the 2,000+ blank CD's I have. (Many free after rebate buys.)
One of the things I didn't like with the LiteOn is that it has only a single input and output. I am also trying a Philips DVR615 that have multiple inputs and outputs. With multiple outputs, I have a set of outputs going to my Harmon Kardon receiver and I have a set of output going directly to my TV. (Easier for the wife to navigate.)
With multiple inputs, I have one set coming from my DirecTivo and another set coming from my reciever so I can record whatever source my receiver is on, Radio, VHS, etc.
Just wish I knew which one would last the longest. Guess from past experience, extended warranties would be a good idea. -
I bought this unit a couple of months ago from Novatech (£199) and am very impressed with it. I record TV via a digital receiver and get a fantastic picture in the 1hr/2hr modes. The 2 highest settings are of a good enough quality for DVD's. The 4 hour mode can be likened to VCD quality. I have used it successfully to transfer DV from my Canon camcorder without any hassle. The feature for all media (except Ram) is a plus point. Although I have only had the recorder for a limited amount of time I am not dissapointed at all.
I highly recommend the Lite On LVW5005.
the 4 hour mode looks quite nice, and is essentially SVCD,
with the following spec: 2.5mbps, 352/480, mpeg2.
I'm amazed at all of the cool features this machine has.
not fluff either, good functional features.
Very easy and intuitive.
It's actually a fun rig. you won't be disappointed.
BTW, the warranty is 1 year parts AND Labor.
Isn't everyone else 90 days?
One time, I had a problem with one of my Lite-On cdr drives, I can
at least say that Lite-On responded to my satisfaction.
I think they're pretty good company.
And no, I don't work for them, but I will go out of my way
to praise good work.
cheers!
Rec.709 to RGB24 to Rec.601
By Anonymous344 in forum Newbie / General discussionsReplies: 8Last Post: 2nd May 2011, 19:40 -
Converting REC to DVD with multi-languagetracks
By Rob- in forum Authoring (DVD)Replies: 0Last Post: 24th Feb 2011, 11:16 -
Suggestions for DVD cases requested
By pooty13901 in forum MediaReplies: 7Last Post: 1st Dec 2008, 14:42 -
can i rec.dvd to the hdd of my dvdr3570 philips?
By fitos in forum DVD RippingReplies: 0Last Post: 8th Feb 2008, 16:10 -
usb connectivity in DVD Rec
By nirbhayn in forum DVD & Blu-ray RecordersReplies: 4Last Post: 13th Nov 2007, 19:30
