  1. Hi guys,
    My newbie question for you might be already touched in time, but it takes a lifetime to scan all the topics here, so, if some of you good samariteans have a few words for me, it's going to be greately appreciated.
    I just got a dvd burner and want to create dvd's with my home-video from the camcorder.
    I capture the 12G .avi and now I'm looking for a way to convert that file into the two folders neded for a dvd.
    I do not want to process audio separat, I do not want to join video and audio, or other "tricks" because I don't have time to spend. I encoded with CCE, make a menu in TmpgencDVD-author and burn with the software that comes with my HP burner. It was ok, but it's really a long process for my time.
    So, give me a name of a software that captures from the camcorder, makes the mpeg2 files with a good quality, makes a menu and burns.
    Thanks guys.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello
    Pinnacle studio does that I believe. I think Roxio also does. Just go to an electronics store and browse the dvd authoring section of the software aisle.
    Kevin
    P.S. DVD only needs one folder {video_ts}. The audio_ts is extra and reserved for the newer dvd-audio discs. If you look at any pro movie discs the audio is always empty if its even there.
  3. Thanks Kevin,
    I'll go look right now.
    Dan
  4. Ulead Movie Factory.....
