You can copy TV shows to the Hard Drive, but can you then burn the ones you want to keep to the DVD recorder, or is the HD just for temp shows that you can eliminate later? If the HD has no ability to burn to the DVD recorder, what good is it besides a temp bin? Dumping through a fire wire is another possibility, but that means a computer must be nearby. I want the recorder to be independent of the computer regarding proximity. I can edit the burned DVD in the computer separately.
The purpose of the HDD in DVD recorders is to do just what you are talking about... recording to the HDD, do simple editing (cutting out commercials, etc.), then burn to a DVD. The HDD can be used simply as a DVR/Tivo time shifting recorder, as well.
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Why do all hard drive DVD recorders suck?
By lordsmurf in forum DVD & Blu-ray RecordersReplies: 105Last Post: 3rd Sep 2008, 23:22 -
What's up with the lack of hard drive recorders?
By jjmdtw in forum DVD & Blu-ray RecordersReplies: 16Last Post: 20th Mar 2008, 13:40 -
New Panasonic Recorders with Hard Drive?
By duffy76 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 15th Jul 2007, 11:51
