What is "bitrate"??
From Glossary:
Bitrate
Bitrate or Bit Rate is the average number of bits that one second of video or audio data will consume. Higher bitrate means bigger file size and generally better video or audio quality while lower bitrate means lower file size but worse video or audio quality. Some bitrate examples in common video and audio files:
MP3 about 128 kbps (kilobits per second)
VCD about 1374 kbps
DVD about 4500 kbps
DV about 25 Mbps (megabits per second). -
https://www.videohelp.com/glossary?B#Bitrate
Bitrate
VCD about 1374 kbps
DVD about 4500 kbps
EDIT: beat me to it (curse you slow internet connection!) -
Hello,
Bitrate is the "quality" of the video and/or audio. The higher the bitrate, generally the better the picture or sound. VCD is low bitrate (1150) and doesn't look very good. DVD (2500 and up) is excellent (some will argue with me on that) because of better compression technology.
Audio bitrate is how well the sound is stored. CD Wavs {before made into mp3) are 1400 I believe. CD Quality mp3 uses 128 bit. Using smaller bitrates save space but usually results in lower quality.
Kevin
P.S. I'm no expert but this should be a starting point for you.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thanks for explaining!!! :D
I've just downloaded the AAA Real Recorder, and the output file's sound is HORRIBLE!! Is it a problem with Sound Card??
"Quality Enhanced Bitrate Squeezer" QEBS FASM Encodes
By iR8 in forum Video ConversionReplies: 9Last Post: 3rd Apr 2013, 19:29 -
HCenc 2nd pass, what to do about: "*** INFO, adjusting average bitrate..."?
By jclampy in forum Newbie / General discussionsReplies: 14Last Post: 5th Jan 2012, 15:30 -
new template "bitrate v1.6.XLS" released
By led in forum Latest Video NewsReplies: 1Last Post: 29th Jan 2011, 14:21 -
TMPGEnc "clip total bitrate too high for a DVD-Video" issue
By dread in forum Authoring (DVD)Replies: 7Last Post: 26th Oct 2010, 16:34 -
TMPGEnc says "clip total bitrate is too high for a DVD-Video" but it's not?
By sasuweh in forum Authoring (DVD)Replies: 24Last Post: 30th Sep 2010, 04:17
