Hi, all.
Is it possible to capture PAL video source using passthrough feature in NTSC camcorder ?
Gekkon
Results 1 to 10 of 10
Yes.
err, no.
Maybe.
Depending on the camera, it would either recognize the source as PAL, and capture it as PAL (25fps, 702*576), or do nothing at all, or capture in B&W or with a vertiacl rolling picture or ...
Why not try it and tell us what happened?
why not capture to NTSC, edit it, and output it to PAL?
i did that for a family video that my mom needed to send over seas, and it worked great. -
Actually I cannot try since I have no such camcorder. Due to some reasons it is much easier for me to obtain NTSC camera, but I live in Eastern Europe, where mainly PAL system is used.
Please be reminded that DV transfer is not really a capture. Also, most camcorders are not dual mode (PAL and NTSC). That said, an NTSC camcorder will output NTSC, which you would transfer (not capture). Therefore your best option is to convert after the fact.Originally Posted by gekkon
2 MpegEncoder
Does it mean that PAL source is transcoded in camcorder into NTSC?Please be reminded that DV transfer is not really a capture. Also, most camcorders are not dual mode (PAL and NTSC). That said, an NTSC camcorder will output NTSC, which you would transfer (not capture). Therefore your best option is to convert after the fact. -
I don't think so, an NTSC camcorder would expect to see NTSC coming in also.Originally Posted by gekkon
2 lenti_75
What connection is between subj and european TV's? I know it, but I don't know if it is possible to capture PAL through NTSC digital camcorder. That's all.
2 MpegEncoder
I think you are right, but I would like to know exactly. Just academic interest (with possible practical consequences).[/b] -
You'd really have to check the specs on the unit you're interested in.Originally Posted by gekkon
NTSC Camcorder feed thru capture from PAL
By INFRATOM in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 29th May 2009, 02:17 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 15:36 -
ntsc tapes pass through pal camcorder into mac for ntsc playing?
By tozier9 in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2008, 18:19 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45 -
Pal and NTSC Camcorder
By NightFire in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 20th May 2007, 21:01
