I was using my Pioneer 107 with DVD Shrink and got an error message. I decided to reset the computer but afterwards the Pioneer was dead. I cannot find it in My Computer and it does not show up in Device Manager. I have checked that all leads are secure but it is just not working. There is a DVD disk inside but I cannot get it out. Can someone help?
Results 1 to 12 of 12
carpe diem maņana
I would open the case remove the drive. Reboot the pc. Then shut the PC off and reinstall the Burner. Also when you have the pioneer out of the case use a small paper clip to remove the dvd that is inside, you should have a small hole place the end of the paperclip into it and the drive will open up. Hope this helps....
I tried what you said but XP is not seeing it to install it. It is not listed in the bios. I have managed to get the disk out. It seems completely dead.
carpe diem maņana -
You might want to try a different IDE cable, a different IDE channel and a different power lead before you call the time of death. Seems like it's probably dead, but a few minutes of diagnostics could save some time and headache if it's not dead.
Nothing can stop me now, 'cause I don't care anymore. -
Excuse my being a bit numb but I presume I just plug in another cable. How do I use another IDE channel?
carpe diem maņana -
Most computers have two IDE channels (plugs on the mainboard or expansion card) called the "Primary" and the "Secondary". The hard drive will most likely be plugged into one port and your optical drive(s) in the other. Either make the drive a slave and plug it into the same cable as the hard drive, or just swap the cables where they plug into the motherboard.Originally Posted by fazza8
Best of Luck,
-Evan- -
When you decided to "reset" your computer, did you power it off properly through Windows or hard reset it?
WesleyTech.com - Blu-ray Disc & consumer technology news, reviews & articles -
I have a Sony Drive that came with the machine as well and I have tried swapping the cables. The Sony continues to function and the Pioneer continues to lie doggo
carpe diem maņana -
Time to either dump the burner or rma it,its toast.
On my way to buy a new one as we speak (well, right after). Wonder whether I should upgrade the firmware on the next one. I upgraded to 1.13 on this one. It has had a pretty busy 6 months!!
carpe diem maņana -
Its usually best to upgrade firmware cause they include the newest media codes for better and faster burning speeds on new media,once in awhile firmwares can be glitchy.
Pioneer DVR-520H: seeking advice for DVR-107-XA drive replacement.
By donglejack in forum DVD & Blu-ray RecordersReplies: 71Last Post: 12th Feb 2012, 09:24 -
Pioneer DVr 107 replacement
By Mrx99 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Jul 2010, 18:49 -
Adobe AME CS4 4.1.0.107 persistent error (SS inside).
By x2x3x2 in forum Video ConversionReplies: 4Last Post: 4th Aug 2009, 01:47 -
Region problem with Pioneer
By bltprf in forum DVD & Blu-ray WritersReplies: 10Last Post: 28th Jan 2008, 05:36 -
Technika LCD TV/DVD 107 Region Hack
By Lustyjd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Nov 2007, 11:10
