Hi all![]()
I'm having problems getting my DVD-rom to read DVD-r i've burnt. I have used SVCD2DVD and also Nerovision Express to burn my home movies onto DVDr. I'm using Ritek GO5 discs and a sony 8x dvd-rw.
The movies play on my DVD Player and in my DVD-rw drive. I even changed my DVD-r drive to a Sony DDU1613 so see if that helped? I can play other DVD-r just not ones I have created![]()
Can anyone please help me before I cry myself stupid?
This is not uncommon. some DVD-ROM drives in computers won't play DVD-r's burnt with a DVD RW drive. Sometimes it takes a firmware update. I know in the case of my AOPEN dvd-rom drive it did.
One way to check, try Nero's INFOTOOL to see what the drive will support. That will tell you right away. Then see if there is a firmware update.
Your dvd-rom is really made by Lite-on model 167T. -
If you are a guy, it's OK to cry, just do it in the privacy of your own home and not in front of anyone.
How to change 720x480 to 640x360 resolution (I'm going to cry :( )
By tutti456 in forum Video ConversionReplies: 4Last Post: 2nd Mar 2010, 09:03 -
Almost made me cry ***MUST SEE*** ;) Muppet fans click here!!!
By MeDiCo_BrUjO in forum Off topicReplies: 7Last Post: 1st Dec 2009, 16:24 -
Problem.. DGIndex reports "motion code error" :cry:
By _migz_ in forum Video ConversionReplies: 2Last Post: 27th Nov 2007, 06:09
