I have an svcd file that has mpeg2 as the video and mpeq1 as the audio, as discovered by running the AVI codec. The file I obtained already had the audio out of sync so I thought I would extract the audio in virtualdub and convert it to wav so that when I used TMP I could put the audio and video in better sync. My problems and questions:
1. VirtualDub gives an error message that it can't find any VIDEO files when I pull up that file in VD. I was trying to extract the AUDIO files so I don't know where to even go with this error message.
2. After reading my thoughts above, do you agree this process would "put the audio and video in better sync"?
Thank you for your help.
Results 1 to 1 of 1
Extract Audio from RM File without Convert it
By Bruno AUgusto in forum AudioReplies: 7Last Post: 13th Nov 2011, 09:48 -
How to extract audio from mpg file?
By paul.1911 in forum AudioReplies: 4Last Post: 9th Nov 2010, 04:35 -
Extract Audio from XviD MPEG-4 video
By MI6 in forum AudioReplies: 2Last Post: 3rd Jan 2009, 06:58 -
Is it possible to extract audio from a non MKV file?
By mvgc3 in forum Video ConversionReplies: 13Last Post: 2nd Apr 2008, 02:09 -
Extract part of an audio file into a new file without rencoding?
By therock003 in forum AudioReplies: 4Last Post: 19th Oct 2007, 17:32
