Results 1 to 12 of 12
    Feb 2003
    Crystal Beach ,Ontario
    Hi guys.
    I want to buy a region 2 dvd from England and change the setting on my dvd player(sonydvpc600d) to
    region 1.If I do this will I be able to make a copy of it?
    Also,is there REALLY a GOOD region free dvd player
    that doesn't cost an arm and a leg?
    Thank you
    dvddiva
    "If Life is a bowl of cherries,what am I doing in the pitts"
  2. Banned
    May 2003
    Massachusetts
    A player that is SOLD as region-free that's cheap? No. Specifically BECAUSE it's region free, it HAS TO BE expensive - they've paid 5 times the licensing fees in order to sell it that way.
    However, if you look in the DVD Hacks over on the left, you'll find many players which can be MADE region free with a few esoteric remote inputs.
    - Gurm
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Make sure it plays PAL discs too. Otherwise you'll have the headache of converting PAL to NTSC.
    Kevin
    P.S. You can also play it on your dvd-rom (you get 4 region changes or look for a regionfree hack for your dvd-rom
    Feb 2003
    Hey guys,
    You didn't answer my first question.Region 2 to region 1
    and then can I copy it?
    Mar 2003
    Uranus
    What do intend to copy it to ?
    If you rip it into a computer it will be ALL region.
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Yeah, sorry about that. Dvd decryptor and dvdshrink will make it all region for you if you select it.
    Kevin
    Feb 2003
    Thanks Foo,
    I want to burn it to a blank dvd or to my hard drive,I don't really care which.
    Did you say that if I burn it to my hard drive,it will become region free?Does that mean I can use any program to transfer it to a blank dvd?
    Mar 2003
    Uranus
    I'm not aware of a program to burn files to a Hard drive.
    Probably not a good idea anyway.
    DVDdecrypter will decrypt and transfer a DVD to your hard drive
    and it will be region free. You can then burn to a DVD.
    Any program will not work. I know for a fact that
    MS Word for example will not burn DVDs. You might consider
    a Burning program.
  9. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    @Gurm, here in the UK quite a few local stores and shops now advertise region free players at under £50 or even less
    I bet they ain't paid any fees
  10. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Don't know about PAL, but here's 'Region Free' for $20.
    http://www.ecost.com/ecost/shop/detail.asp?dpno=449447
    Nothing can stop me now, 'cause I don't care anymore.
  11. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    $10 manufacturer mail in rebate with purchase of a Yamakawa DVD-238 through September 30th, 2004
    $8 mail in rebate when you purchase a Yamakawa DVD-238 with the purchase of $500 from eCOST.com on a single invoice. June 10th - August 20th, 2004
    $7 eCOST.com mail in rebate when you purchase a Yamakawa DVD-238 from June 10th, 2004 - August 20th, 2004. Rebate available only from eCost.com !
    just in case people don't notice but it's still cheap even without the rebates anyway
  12. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Yeah, I think I'd miss out on that $8 rebate. Not gonna buy $500 worth of stuff to save $8 on a $45 DVD player. :P But as you said, even without any of the rebates it's still cheap.
