Hail assembled gurus of the DVD world !
I need help with a specific problem i cant seem to get rid of or find the cause of. Im trying to rip a specific segment of a DVD movie so that i can then include it in a media clip which im creating in Vegas.
Ive done this countless times and have never experienced this issue.
Im using the latest DVD shrink and Vegas 5.
When i look at the VOB of the re-author i just grabbed (using media player), i notice some heavy pixelation stripes in areas of the video. It looks like a satellite TV signal which is experiencing interferance in some areas of the picture. It happens in the same place in the movie every time. If use WinDVD to have a look at the file, its fine - no pixelations or intereference at all.
Is this a codec issue ?
If so, how can i clean out my DVD codecs so that i can find one which works ?
Im really struggling for a solution here and time is running out for the media clip to be completed. Ive tried using 2 different DVD drives and different versions of shrink. Is there another app that does the same thing as shrink as far as capturing raw segments directly off a DVD ?
All help is TRUELY appreciated.
Cheers[/b]
[b] PROBLEM partially FIXED
I uninstalled WinDVD and then installed the mpeg2 codec -
https://www.videohelp.com/tools?tool=323#comments
Now the VOB looks good in media player but is still pixelating in Vegas. Anyone know how i can specify Vegas to use the mpeg codec i want ?
Thanks for the help by the way gurm -
After trying several different theories, im still at the same point. Can anyone please suggest a fix ?
*bump*
Partial upconvert of DVD, add black border = Bluray
By HDTV's Frank in forum Authoring (Blu-ray)Replies: 3Last Post: 13th Jun 2011, 01:15 -
Pixelation Problem
By Renta in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2009, 22:46 -
Problem using DVD shrink 3.2
By aldago in forum Newbie / General discussionsReplies: 12Last Post: 13th Feb 2009, 20:28 -
Partial Conversion of avi to DVD
By macsnooder in forum ffmpegX general discussionReplies: 2Last Post: 7th Feb 2008, 01:54 -
Which Noise/Pixelation filter would be best for this video?
By mlong30 in forum RestorationReplies: 3Last Post: 17th Jun 2007, 18:03
