hi there
I'v been given a dvd by a client and he wants me to rework the menu's
how do i extract just the main movie/bits he wants so that i can reauthor in dvdlab ???
There are LOTS of ways to do it.
ONE way, using free tools, is this:
1. Rip ALL files to your HD with DVD Decrypter.
2. Use IfoEdit (its DVD in build player) to determine what Titles (and what VTSs) you actually want to keep.
3. Having ascertained what VTS files you actually want demux them with VOBedit.
4. You will end up with separate Video, Audio (and Subtitle if any) files. These files can then be used as they are to re-author with DVDlab.
The above 4 steps will keep a title "together". If you also need to select only certain clips from a title then you need to edit. You can edit your MPEG files (obtained in step 3 above) with MPEG2Schnitt (for example).
To know how to do each of the steps above look to the Guides section and search for guides for each of these tools. They are there except for MPEG2Schnitt. For this one go to its website.
Hope this helps.It wasn't me.
DVD reauthoring problem: 1 movie on 2 DVDs
By WIGGER in forum DVD RippingReplies: 10Last Post: 23rd Jan 2012, 17:10 -
DVD Reauthoring - Removing a menu
By xDarKnighTx in forum Authoring (DVD)Replies: 2Last Post: 2nd Jul 2010, 00:32 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 19:27 -
How to full backup (no encoding) BR main movie, main audio with subtitles ?
By meico1234 in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2009, 03:37 -
Removing Menus from DVD without Reauthoring?
By ufcdanny in forum Authoring (DVD)Replies: 3Last Post: 2nd Sep 2008, 04:40
