is this possible...![]()
i have a bunch of mp3s and id like to put them onto a dvd-r and play them in my DVD player.....i know you can make cd-r's with mp3s on them and play them on most dvd players but can you do it on dvd-r somehow....if you can how....what programs do i need...so on....
thanx for your help![]()
Results 1 to 9 of 9
you should check the dvd player listings on the left to se if your player can play mp3-dvd's first.
i have a.....
-Sony DAV-FC7
-Panasonic CV51
-Panasonic PV-D4733
so once again...
is this possible...
thanx for your help -
You know, you can look it up yourself, on the left hand side theres a button that says "DVD Players". anyways, from what I looked up, it seems that your Sony DAV-FC7 can play mp3-dvd's. Use Nero, and make sure you're in DVD mode and just select 'mp3 disc' then add all the files you want then burn it.
I burn my mp3 with nero, and dvd-rom option. My lg-7942 standalone can play it with no problem. Try with a dvd-+rw, if your standalone can play them.
sorry i made you look it up....
but it looked like to me that none of my did play them
i figured mp3 of cdr-mp3 not dvd-mp3...not trying to be a @ss or anything but thx for clearing it up... -
hmmm....it didnt work....says cant play disc...i guess i cant play them ohh well
Low auido on WMP with DVD codec
By janlafata in forum Software PlayingReplies: 3Last Post: 15th Jul 2009, 00:31 -
how can we add audio in dvd from vcd auido..
By sozerun in forum Newbie / General discussionsReplies: 1Last Post: 3rd Nov 2007, 19:06
