  1. i used to b able to do this with goldwave no problem,but i had to format pc recently & now it refuses to do it,virtualdub refuses too.How can i get the audio out of this bastarding xvid,i seem to have ac3 codecs installed fine,any help would b appreciated
  2. Member Grimey's Avatar
    May 2004
    Canada Eh?
    check it with Gspot to see if you do have the right codec(s) installed.
  3. gspot says i have 5 compatible codecs
    try install the AC3 ACM Decompressor and you should be able to use virtualdub to extract to wav.
