Page 4 of 5
FirstFirst ... 2 3 4 5 LastLast
Results 91 to 120 of 130
  1. ddlooping
    For DVD Shrink guides & goodies: DVDShrink.info
    My "other" site: Teaching-Tools
  2. Banned
    May 2003
    Massachusetts
    That would be GUNNERY SERGEANT R. LEE ERMEY, to you... MAGGOT!
  3. I don't know, but I've been told...
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  4. ...DVD Shrink is as good as gold!
    George Carlin
  5. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    BULLS**T!!! I CAN'T HEAR YOU!!!
    Nothing can stop me now, 'cause I don't care anymore.
  6. HO CHI MINH IS A SON-OF-BITCH!
    GOT THE BLUEBALLS, CRABS, AND THE SEVEN-YEAR-ITCH!
    George Carlin
  7. Originally Posted by Gurm
    Rabid maggot.
    ddlooping
    Jul 2003
    I can't believe that nobody has pointed out the obvious mistake in Gurm's well put together fact list. The extra's can be removed by simply re-authoring the disc. That let's you pick and choose what gets put onto the copy. 8)
  9. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    lol, this is an old issue Thunder and it does not remove the extras as you are creating as in authoring a DVD therefore you are adding content to nothing you have at the minute and not removing content
    simply put, you start off with an empty project which you then add content too
    you mention you can remove the extras but why do people forget to mention you also lose functional menus if you reauthor? There's a difference between removing extras and removing extras and menus . I know there are methods in which you can rebuild etc with menu's but we are talking basic stuff here within the DVDShrink program
    after this thread was posted, the new version of DVDShrink can now replace the extras with a still image so it changes things slightly but not in the reauthoring mode
  10. Banned
    May 2003
    Massachusetts
    DVDShrink 3.2 is, in fact, possessed of MORE CREAMY GOODNESS than ever before found outside of Twinkies. It can, in fact, "remove" extras without reauthoring. It can also automate burning with DVD Decrypter.
    The other myths, however, stand.
  11. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    It still does not REMOVE extras. It merely shrinks the size that they would normally take, substituting a still pic. To truly remove parts ( Disney ), you need something like DVDRemake.
  12. Member wulf109's Avatar
    Jul 2002
    It doesn't actually delete extras,but it has a new option to substitute a DVD Shrink logo screen for the video. It says that will still use 81MB.
    CloneDVD will delete the extra and insert an 8KB file,still much better option than DVD Shrink.
  13. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    to be technical, nothing actually removes the extras as they all just replace the original with a blank video . DVDRemake also replaces anything that is removed and does not remove them. If you want to be non-technical then DVDShrink does now remove the extras if you want as it's getting rid of 100% of the original content and replacing it with longer blanks to keep the original structure
    it's removed but it's been replaced
    so it's pointless saying this and that doesn't or doesn't remove extras as none of them truely do apart from one as they replace them. InstantCopy is the only one I have seen recently that removes them completely and destroys the original structure by doing so
    DVDRemkae does actually completely remove video content but only if it is not referenced in the IFO's anywhere
    if you use the correct blank in DVDShrink then it will use 30mb per 1GB that you replace which is not a lot of space and it's far better than CloneDVD in most areas of it's features
    the only disadvantage with DVDShrink is that the play time is still the same so removing logos etc requires you to press skip unless you want to look at a blank screen for 8-10 seconds or whatever it can be sometimes
    if you are clever enough or can be bothered, you can do a little hack I've been trying and get rid of this. I've contacted DVDShrink about implementing it into Shrink. I'm hoping it would be real easy but as of yet no reply which is very disappointing even if it was just a brush off a reply would have been nice (ddlooping where are you as maybe you can mention it? )
    if not I'm sure some computer whizz can knock up a simple program with me that does it for you if people are interested. If not maybe I can do a dummies guide for all the 'freebieware' users out there
  14. DVD Shrink just took my garbage out & cleaned my garage.
    George Carlin
  15. Member louv68's Avatar
    Feb 2004
    Minneapolis, USA
    MackemX,
    I believe I read on another site that ddlooping aka Mr. Shrink, will be away for the next two weeks.
  16. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    lol louv68 , ddlooping is not aka DVDShrink if you are not joking though some do think it . Maybe he is but I remembered about ddlooping being on holiday as it was mentioned in a 'warm' thread I posted in over there. I don't think he's back yet but I know someone read the PM I sent to DVDShrink though. I was a bit disappointed at a non reply even if it was a 'go away and stop wasting my time' but maybe he's real busy so I'll just wait in hope I suppose and maybe ddlooping can help when he gets back
    @Shocker Milwaukee, I don't really care for backing up DVD's but where's those options as I'm looking for exactly the same features along with washing the car and taking the dog for a walk
  17. Originally Posted by MackemX
    Yes, DvdReMake replaces with a short blank to reduce the size and to keep valid dvd structure. But in addition to this it also automaticaly changes dvd navigation so that hidden things are not get played.
    So this does not happen with DvdReMake (Pro).
    http://www.dimadsoft.com - home of DvdReMake and MenuEdit tools
  18. Member
    Jul 2004
    Pacific NW
    I think DVD Shrink would be an even better tool when:
    1) It rips as fast as DVD Decrypter
    I've encountered a few movies DVD Shrink won't rip. DVD Decrypter seems to take care of those.
    Of course, has anyone encountered a movie that DVD Decrypter could not handle but DVD Shrink could?
    Jul 2003
    Ontario, Canada
    Some of my Homemade videos using Philips DVDR75 recorder (record, edit, replace thumbnail frames etc.) cannot be ripped (or imported) by using by either. However, with MackemX's tips (earlier threads) of copying directly to HDD with Windows file explorer, I am now able to make copies of my own movies with file copy and NERO.
    Thanks, MackemX.
    Sam Ontario
    Jul 2003
    Yes Mack, I did mean in the re-authoring process as this is the usual method I use when copying a movie, excuse me, backing up. Depending on how you think of it, yes, it's either removing or "creating" as you put it, and I see your point, as you pick and choose what the new disc will contain from the original. But why would you want to keep menu's? They're annoying and waste precious disc space, especially if they're really crazy like ID4 or The Abyss. Isn't it nicer (yes, I know, grammer) to just throw the disc in, and start the movie right away, then waiting through 40-50 seconds of menu's? We all know what a pain the ass "Memento CE" was to navigate. :P
  21. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    @Thunder, menus or no menus, that is the age old question and it was in no menu's favour a few months back but I'm not so sure now with all these blanking tools
    no probs Sam Ontario
    @DVD Polizei, it just depends on the circumstances such as the reader, the disc, the condition etc as I've used a combo of 3 readers and 3 rippers to rip a problem disc before as 1 reader and ripper just would not do it. I wouldn't say one is better than the other but rather just use what works at the time
  22. Banned
    May 2003
    Massachusetts
    I _like_ the menus. If I'm impatient, I hit "1" on my DVD remote to start the movie without watching them. But how am I going to pick what scene I want from the cool animated menu without the menus BEING THERE?
    - Gurm
  23. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    [quote]DVD Polizei- think DVD Shrink would be an even better tool when:
    1) It rips as fast as DVD Decrypter [quote]
    Actually, it only rips like decrypter if its a dvd5 (ie 4.7gb or less). If its a dual layer than its TRANSCODING as it rips. So of course it will be slower. Dvd Decrypter is great for taking everything bit for bit from the disc. It won't SHRINK it. That's the whole point of dvd shrink.
    Kevin
  24. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If it's 4.7GB or less, why use Shrink at all?
    If in doubt, Google it.
  25. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Hi STALKER!
    jimmalenko-If it's 4.7GB or less, why use Shrink at all?
    Well some people like using the same program all the time. Actually I was making the point that shrink transcodes AND rips when it's a dual layer disc. If its a single layer then it acts like dvd decypter - ie straight rip.
    I have used dvd shrink for single layer discs just because. No reason in particular. Some people like the interface better than other programs.
    Kevin
  26. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Hello,
    Hi STALKER!
    Kevin
    I wasn't specifically aiming at you, just wanted to let the masses know that it is not essential to use DVDShrink on DVD-5s. I understand the point you were making
    I prefer DVD Decrypter ISO Read/ISO Write for DVD-5s.
    For anyone that is interested:
    ISO Read guide here
    ISO Write guide here
  27. Banned
    May 2003
    Massachusetts
    This is one of the things I have a problem with.
    If it works for you, great - but I'm a big fan of "the right tool for the right job".
    - Gurm
  28. The only one that integrates with Shrink is Nero
    Hmmm...I've used DVD Decrypter to burn with shrink, both that and DVD Shrink is all you really need. Maybe not the best Ripper but the transcoder is tops! some may be considered better but it really is relative to the original source.
    It is a pretty amazing piece of software...I just backed up Return of the King with 3.2 and it looks amazing. It is free and it does most everything as good if not better than comparable apps.
    Don't be a hater Gurm.
    Look, let me explain something. I'm not Mr. Lebowski; you're Mr. Lebowski. I'm the Dude. So that's what you call me. That, or Duder. His Dudeness. Or El Duderino, if, you know, you're not into the whole brevity thing--
  29. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    I don't think he hates DVDShrink but rather the people who think DVDShrink is the number 1 tool to do anything at all to do with DVD's regardless of what it is just because it's 'free'
    a few things have changed since the latest release of DVDShrink so it's a little outdated now
  30. Member
    Apr 2003
    I even use DVD shrink in Linux with crossover office. I found it to be fasterin Linux than in XP on the same machine (Dual Boot). I've tried a lot of others and all I've tried wont work with wine or crossover as good as this does.
