I've been trying to encode a video with TMPGEnc and after it is done, the video looks like it is playing in slow motion and the audio sounds like it's coming out of a tin can. It is an XviD movie with the new codec. I've tried using Vdub to re-encode to DivX but it comes out the same. It's as if they are both deleteing frames and the movie comes across more like a slide show than a video. Has anyone ever had this trouble before, and if so what do I do to fix it so I can burn the movie to VCD or DVD? Thanks a lot in advance.
what is the frame rate of the original and what is the frame rate you are encoding it to ?
The origional is 25.000 and I'm converting to NTSC for a VCD which is 29.97 correct? This is all still pretty new to me. I checked the frame rate in Vdub. Can I change the framerate and encode with DivX in Vdub then encode with TMPGEnc to MPEG1 without messing up the video? Or what should I do?
Super slow motion video experimentation
By snafubaby in forum Video ConversionReplies: 3Last Post: 27th Mar 2012, 10:45 -
MP4Cam2AVI converts my video to slow motion
By sozuki in forum Video ConversionReplies: 2Last Post: 5th Jan 2012, 17:31 -
old 1988 home video with TERRIBLE slow motion - trying to edit that in 2008
By AcesOfClubs in forum RestorationReplies: 9Last Post: 28th Jan 2008, 09:49 -
By AcesOfClubs in forum Video ConversionReplies: 1Last Post: 25th Jan 2008, 12:33 -
convert DVD segment to slow-motion video
By jackieO in forum Video ConversionReplies: 2Last Post: 7th Oct 2007, 15:36
