I would like to make one Mpeg2 file from a DVD so I can edit it.
If I use DVD Decrypter I have to do stream processing. I get two files. The first file contains the video (mpeg2). The second file (*.VOB) contains the audio.
What parameters do I have to set in order to get one file (for the video and the sound)?
Thanks,
Joost
You're a bit confused.
.VOB files are mpeg2 system streams - video AND audio.
Why do you "have to" do stream processing?
- Gurm -
i believe you are trying to demux the streams. highlight each selected stream seperately and click demux. the video and audio will then be in two seperate files when ripped.
Thanks, I know that VOB=MPEG but I cannot edit them if I just change the extension.
I just want ONE Mpeg file (with sound and extension). -
2 solutions:
[1] Use a program like TMPGenc. Do FILE -> TOOLS -> SIMPLE DEMULTIPLEX, type *.vob, then choose your big VOB file. Demux to ac3 + m2v. The use BeSweet to convert the ac3 to mp2 track, and finally use TMPGenc and do FILE -> TOOLS -> SIMPLE MULTIPLEX and choose MPEG-2 VBR and re-mux the mp2 and m2v file to get an editable mpg file.
[2] (Simpler) Use Womble Mpeg VCR and choose TOOLS -> FORMAT CONVERSION and enter the name of the VOB file, then choose ALL (video + audio) and select then output name, then SAVE, then CONVERT. You'll get a file name (whatever).mpg that you can now edit with a program like Womble Mpeg VCR or M2 Edit Pro. -
Wouldn't it be simpler with MPEG2VCR to just edit the VOB
and save as a MPEG2 ?
DVD Decrypter 3.5.4
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 9th Mar 2010, 14:48 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
DVD Decrypter
By Beaker14 in forum Newbie / General discussionsReplies: 17Last Post: 26th Oct 2007, 22:39 -
Help with DVD Decrypter
By Me-Hostage in forum DVD RippingReplies: 10Last Post: 20th Aug 2007, 08:12 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
