I have 17 AVI's that are the seuquels of a TV serie. Each is about 350 Mb.
I would like to burn these in such a way that they can be viewed on a standalone player. And I want to combine several of them onto 1 DVD.
What is the way to do this??
Append them one onto another using QT, exporting to AVI and then FFmpegX. Or is/are there better ways.
Thx
You can fit either 4 or 8 episodes on a DVD. 8 if you encode them at 352x480(576), so this may deteriorate the quality.
The best way is to encode them in MPEG-2 for DVD and author DVDs with a menu to select the episode you want.
Use Tmpgenc or MainConcept or CCE Basic to encode to MPEG and then Tmpgenc DVD Author or DVDLab to author the DVD. Tmpgenc encoder and author program as well as DVDLab are available as trialware for a limited period but with full functionality.The more I learn, the more I come to realize how little it is I know.
Encode each file separately with DVD preset then use Sizzle or DVD SP to author them as a single DVD with a menu.
script to append numbered .avi sequence via AviDemux?
By MilesAhead in forum Video ConversionReplies: 2Last Post: 13th Jan 2010, 01:24 -
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
Cannot append some AVI files in VirtualDub.
By StehpenRH in forum EditingReplies: 3Last Post: 8th Oct 2008, 05:51 -
Problem with Append AVI in VirtualDub - Audio of Sync - How Fix?
By Chakra in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 19:00 -
Append the same AVI file on 70 different AVI files?
By Speed Demon in forum EditingReplies: 3Last Post: 15th Sep 2007, 05:55
