Hi
What is the best settings for converting VIDEO_TS for storage? I'm looking for minimal quality decrease. Also I'm not sure whether to keep special features and subtitles. Is there anyway all this can be done?
THanks
Results 1 to 11 of 11
Hello,
Is it on the disc or the harddrive (and size, over 4.7gb?) If its on disc use dvdshrink. If not use a divx encoder and make it any size you want.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Open the VIDEO_TS folder from your hard drive in ffmpegX and select the DivX preset. Hit encode.
major should I ignore the special features and subtitles? When I select the divx preset as shown on your web site, should I add any extra options or just go with the preset? Once I've converted to divx what is the best player to use? Should I use quickime but then i need a divx codec?
When you say 'storage', do you mean storing them on a harddrive or on removable media? If media is it tape, CD, DVD, what?
In that case just do what Major said.
As far as playback goes, VLC is good if you dont want to install any codecs. Otherwise I would suggest Cellulo but you'll need the appropriate QT codec for whatever you're playing back.
Subtitles should be extracted as VobSub files (.idx/.sub pair) with the "Extract" button. Additional features can be kept only if they are video streams (no interactive stuff), by setting the "Title" number and encoding them separately. To get more quality, enable the checkboxes in the options tab. See the online manual to know what they mean. Use the PSNR tool to measure the quality increase vs encoding speed decrease for each option.
Originally Posted by cookieme
Chapters missing or out of sequence when converting VIDEO_TS to .AVI or MPE
By Sloani in forum ffmpegX general discussionReplies: 2Last Post: 7th Mar 2010, 10:45 -
Help With Converting VIDEO_TS to .AVI
By c4ry in forum Video ConversionReplies: 2Last Post: 15th Dec 2009, 02:15 -
When converting VIDEO_TS to DivX, why is only the first file encoded?
By SheerGold in forum ffmpegX general discussionReplies: 5Last Post: 10th May 2009, 11:41 -
Converting a Video_TS folder into AVI
By HankE in forum ffmpegX general discussionReplies: 11Last Post: 6th Jan 2009, 14:48 -
No sound when converting DVD (VIDEO_TS)
By jompa in forum ffmpegX general discussionReplies: 3Last Post: 18th Oct 2007, 16:48
