I want to take a existing movie file using VirtualDubMod and crop some wording out. But what format and other settings would I need to save it in to try to keep the same Size and Quality the same?
I am showing a picture of what the file is at now
Audio is currently MP3 but variable bitrate (this gives a marginal benefit in size and lot's of playback and editing problems)
I'd suggest you compress with MP3 codec at 64kbps joint stereo at 24kHz sampling rate.
Video is currently DivX 3.11 (old movie) at 542kbps and 983 keyframes for 50198 total frames (gives 1 keyframe every 50 frames or so).
I also noticed the interesting frame rate: 14.985 fps. This probably helps keep the file size half of what a normal 23.976 or 25fps video would have.
To make things faster, if you only want to edit a portion of the movie, cut the movie in pieces using direct stream copy (fast and doesn't recompress) edit the portion you want and append the whole lot. However, before you do that you need to convert the VBR audio to CBR (otherwise you will have audio sync problems).The more I learn, the more I come to realize how little it is I know. -
Ah...the glorious world of TMD. Those files are total crap. I tried converting them to DVD, and never could find a way to make them watchable.Originally Posted by john510You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik
best xvid settings for high quality
By dirtyharry61 in forum Video ConversionReplies: 20Last Post: 21st Mar 2016, 09:49 -
Handbreake & Vidcoder picture size problem (HD settings)
By Chainsaw_1 in forum Video ConversionReplies: 3Last Post: 13th Mar 2012, 12:41 -
How do I pick settings to optimally re-encode video for reduced file size?
By bootyhound1 in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 16:16 -
what display size should I use in TV card settings
By jimdagys in forum Capturing and VCRReplies: 1Last Post: 8th Apr 2008, 21:51 -
Settings in ffmpegX for odd size .avi files
By sknox in forum ffmpegX general discussionReplies: 2Last Post: 8th Jul 2007, 23:32
